Activity Forums Apple Final Cut Pro Video Capture & Scratch Disk solution for Mac Pro (Late 2013) / Final Cut Pro X
  • Video Capture & Scratch Disk solution for Mac Pro (Late 2013) / Final Cut Pro X
    Posted by John Oshea on March 27, 2021 at 11:43 am
    Hi, i currently have a Mac Pro (Late 2013) with the following configuration:
    Processor 3.0GHz 8-core with 25MB of L3 cache
    Memory 64 GB 1866 NHz DDR3
    Graphics AMD FirePro D700 6 GB
    Storage 1 TB Macintosh HD
    macOS Big Sur Version 11.2.3
    Display Apple Thunderbolt Display 27-inch (2560 x 1440)
    And i wanted to know what would be the best solution for capturing & ingesting Audio Visual Clips from VHS Tapes & DVD PAL (Blackmagic PAL – 10 Bit Uncompressed) as well as import CD Tracks into my prospective Final Cut Pro X Project.
    At present i currently intend to use the following Video Playback Devices:
    Sony DVP-NS76H
    Sony SLV-SE820 VHS Player (Gold Plated Scart Connectors)
    At present i currently intend to use these following Video Capture devices:
    Blackmagic Ultrastudio 3D (Thunderbolt)
    Canopus ADVC300 (Advanced Digital Video Converter)
    elgato video capture (Capture analog video for your Mac, PC, iPad and iPhone
    Other Options:
    Blackmagic UltraStudio 4K Extreme 3
    Blackmagic UltraStudio 4K Mini
    Blackmagic UltraStudio HD Mini
    The aim of my Final Cut X Project is to create Mashup (video), Music Video, Silent Movie, Short Films, Mashup (music) derived from VHS Tapes & DVD PAL, CD Tracks (Vinyl Records) sources.
    Audio Onlly Soundtracks derived from Soundbites and CD Track samples to put on ipod shuffle.
    Is there any other way i can go about capturing & ingesting Audio Visual Clips from VHS Tapes & DVD PAL (Blackmagic PAL – 10 Bit Uncompressed) as well as import CD Tracks into my prospective
    Final Cut Pro X Project at the optimum standard? Would it serve me best to upgrade my Mac Pro (Late 2013) Grapics card if necessary? Would i need to think about upgrading my present Video Capture device (Blackmagic Ultrastudio 3D -Thunderbolt) to achieve this goal?
    Further to this would you be able to recommend a ideal make & model Scratch Disk & Storage Device for my prospective Final Cut Pro X Project.
    At present i currently intend to use the following External Hard Drives as a scratch & storage disk:
    Lacie Little Big Disk Thunderbolt 2 1TB (Read/Write Speed Up to 1375 MB/s, Up to 1180 MB/s)
    SanDisk Extreme PRO® Portable SSD V2 2 TB SDSSDE81-2T00-G25 (Store CD Tracks) (Read/Write Speed Up to 2,000 MB/s, Up to 2,000 MB/s)
    Other Options:
    LaCie Dock SSD PRO 4TB Desktop External Solid State Drive in Black (Read/Write Speed Up to 2,800 MB/s, Up to 2,100 MB/s)
    Taking into consideration i will be using Multi-Effects & Transitions & Keyframing to these Master Cips & Sub Clips etc.
    I’ve sent pdf & photo attachments of the devices i currently have for your perusal, and Hi, i currently have a Mac Pro (Late 2013) with the following configuration:
    I patiently await your advice & recommendations on this matter.
    Kind Regards
    Patrick Donegan replied 5 years, 5 months ago 2 Members · 1 Reply
  • Patrick Donegan
    March 27, 2021 at 10:35 pm
    It sounds like you have a very professional setup, so it would help if you hired a professional that could do what you ask.
    Have you ever edited before?
    Have you started to injest the video clips?
    Is that not working?
    Do you own the content of all these VHS tapes and CD tracks?
    have you looked at larryjordan.com and other tutorials?
    What is your budget?
