Activity › Forums › VEGAS Pro › Video Capture Problems
  • Video Capture Problems
    Posted by George12 on November 16, 2007 at 11:05 pm
    Using Vegas 7.0e Pentium 4 , 1 Gig RAM
    Captured 8 DV tapes with no problem however when I tried to capture tape #9 I click on Capture Video icon recorded for a second and video capture screen froze while the camcorder kept on playing, can see on camcorder screen footage. I tried withtape #10 and 11 and same result. Can’t understand why suddenly the problem. Help.Did reboot however problem did occur again.
    George12 replied 18 years, 10 months ago 4 Members · 11 Replies
  • 11 Replies
  • George12
    November 17, 2007 at 1:16 am
    A follow up to my issue. I noticed when I click on the play button in the Sony Video Capture box the tape starts rolling normally. When I press Capture Video Icon th start captiring the video then the video screen freezes
  • Rick Mac
    November 17, 2007 at 4:10 am
    Are you out of hard drive space on your capture drive?
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • George12
    November 17, 2007 at 2:18 pm
    No way I have 400mb of free hard drive space. In addition if the firewire cable was bad would I still be able to view footage in preview window. It runs fine until I click on Capture Video icon and then preview window freezes. It seems strange that I was able to capture 8 tapes then all of the sudden can’t capture anymore. Could use some more suggestions of what the problem might be. Thanks George
  • Mike Kujbida
    November 17, 2007 at 3:11 pm
    That’s it?
    DV is approx. 13.5 GB/hr.
    Your 400 mb is under 2 minutes of video.
    You need a bigger hard drive for all your video. Externals are very cheap these days and a 500 GB. model is what I’d recommend.
    Use it strictly for video storage.
  • George12
    November 17, 2007 at 5:53 pm
    Sorry I meant 400 Gig of space. An added note. I decided to capture file on another hard drive, call it Drive B, and I was able to capture. Thus Nothing wrong with camcorder or cable or software. For some reason the other hard drive, call it drive A, is not able to write capture video. When I capture the new material on other hard drive, drive B, I copies all AVI to other hard drive, drive A, and I was able to copy files. I think my problem might be with buffer underrun. Could it be tha hard drive I am having a problem can’t keep up with writing footage or maybe not enough buffer to keep up with hard drive. Any thoughts? Thank You George
  • Edward Troxel
    November 17, 2007 at 11:11 pm
    Is your hard drive up to speed? Is it running in DMA mode? Or has it dropped to PIO for some reason.
    I have the same issue on this laptop. It has two hard drives built-in – I can’t capture to drive “C” but I can capture to drive “D”.
    Edward Troxel
    JETDV Scripts
  • George12
    November 17, 2007 at 11:57 pm
    Thanks for reply. How can I tell if I drive is running in DMA mode. If it is’t how do I switch to it. If I had to switch to it will my data in hard drive be in jeopardy? Thanks George
  • Edward Troxel
    November 18, 2007 at 4:15 am
    Data will not be in jeopardy. It’s in the Windows setup for the drive.
    Right-click “My Computer”, go to Properties, Go to the Hardware tab and click on “Devices”.
    You would then go to the “IDE” controllers entry, go to the Primary IDE controller (assuming that’s where the hard drive is connected), right-click that and choose Properties.
    Now go to the “Advanced” tab and there you will find the various settings. The “Transfer Mode” should read “DMA If Available”.
    Edward Troxel
    JETDV Scripts
  • George12
    November 18, 2007 at 8:01 pm
    Thanks for reply. I did just that and it states
    Secondary IDE Channel ( this is an external USB drive 2.0)
    Device 0
    Devise Type Auto Detection ( Grayed out)
    Transfer Mode DMA if available
    Current Transfer Mode PIO Mode
    Can’t figure out how to change to DMA mode.
  • Edward Troxel
    November 18, 2007 at 10:21 pm
    Well… at least you now know WHY.
    What if you connect it via firewire instead?
    Edward Troxel
    JETDV Scripts
