Activity Forums VEGAS Pro video capture problem in vegas pro 11
  • video capture problem in vegas pro 11
    Posted by Kevin Mccarthy on October 30, 2011 at 6:03 pm
    I just bought a new Toshiba I-7 computer and installed Vegas Pro 11. It seems to edit OK with existing captured footage. HOWEVER, when I try to capture footage, the capture window will “play” video smoothly from the camera (Sony A1-U) but when I try to capture video it captures 1 to 5 seconds at a time and saves these pieces as seperate clips. I have disabled “HD scene selection, so that is not the problem, I have adjusted buffer memory in the capture preferences from one end to the other and video qualty settings as well. Nothing seems to make a difference. Any suggestions?
    Thanks for your assistance.
    Kevin Mccarthy replied 14 years, 10 months ago 2 Members · 2 Replies
  • Nigel O’neill
    October 31, 2011 at 6:37 am
    I am not having such issues capturing from HDV tape into SVP11. I have only experienced such problems with drop outs on the tape, which causes a new clip to be generated each time.
    One thing to check is your 1394 firewire driver which you might have to either check for updates for, or downgrade it to a legacy driver. My windows 7 system is using such a legacy driver as it was not recognising my cameras. I have noticed my laptop firewire completely drops out after 30 or so minutes in a live capture environment, but I have not bothered rolling back the driver as I was only experimenting.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Kevin Mccarthy
    November 6, 2011 at 11:27 pm
    OK, I figured it out!!
    In the default overall preferences the capture program was set to “internal” after changing to “external” capture program all is well.
