Activity Forums VEGAS Pro Video Capture Problem
  • Video Capture Problem
    Posted by Rich Stahle on January 29, 2006 at 5:03 pm
    I posted this awhile back w/no solution or suggestions so here goes again.
    When I launched video capture using the video capture command in the file menu of Vegas everything works fine.
    When I launch video capture using the vidcap60.exe in the Sony directory – it will not connect to a device and the advanced application controls are blacked out (do not work).
    Any ideas?
    Everything else w/Vegas works fine. Sony Vegas 6.0c
    UVTV Productions
    Damaged Goods
    Rich Stahle replied 20 years, 8 months ago 3 Members · 3 Replies
  • Steve
    January 29, 2006 at 6:53 pm
    I just tried your way of running Vegas Capture and it worked fine. I’m running version 6.0a. Don’t really know if that will make a difference.
    You might try re-installing Vegas.
  • Mike Kujbida
    January 29, 2006 at 7:08 pm
    Odds are that you’ve somehow set it to use “internal capture” whixh is meant for HDV. To change it back in Vegas, got to Options – Preferences – Video and select “use exteranl capture application”. If it’s not already pointed to C:\Program Files\Sony\Vegas 6.0\VidCap60.EXE, browse to this location and select it.
  • Rich Stahle
    January 29, 2006 at 7:58 pm
    that was already set.
    video capture works fine when called in Vegas.
    It doesn’t work when run standalone for me.
    UVTV Productions
    Damaged Goods
