Activity Forums VEGAS Pro Video Capture & Firewire Drives
  • Video Capture & Firewire Drives
    Posted by Rich Stahle on August 25, 2005 at 4:49 pm
    I have a 200GB Maxtor One Touvh Firewire Drive.
    I was able to capture to it quite successfully w/no dropped frames etc, however now I seem to be having problems lately.
    What happens is, after capturing some clips, the firewire drive will be dropped & can no longer capture clips without rebooting the drive and sometimes without rebooting the PC.
    It is as if the firewire connection after capturing decided to no detect the drive anymore and won’t unless rebooted.
    Why is is?
    And why all of a sudden now after no problems for several weeks?
    Any ideas? Clues?
    Underground Video Television
    Allen Zagel replied 21 years, 1 month ago 4 Members · 4 Replies
  • Donatello
    August 25, 2005 at 4:58 pm
    a few times over past years i’ve had 1394 drives disconnect .. i thought rebooting help but in the end the cause was the 1394 cable .. … the old 1394 cables worked 80% of the time BUT the 20% will drive you up a wall ..
  • Rich Stahle
    August 25, 2005 at 5:47 pm
    most times I don’t touch the cables . . . . powering down the 1394 drive and/or resetting the computer does the trick. It is JUST ANNOYING!
  • Dirk
    August 25, 2005 at 9:43 pm
    I used to have that issue before I got a real Texas Intruments chip 1394 card. Also there was an issue with older ADS/pyro external cases.
    Good luck, it can be very frustrating.
    Dirk
  • Allen Zagel
    August 26, 2005 at 12:18 pm
    HA!
    I also have 2 Maxtor One-Touch 200gb external drives and have had the same problems. At times, one or both don’t even show up in windows explorer. I think it is the cables. Usually I just pull the cables for a minute and plug them back in and no more problems for a while.
    It hasn’t happened for some time now, but I don’t capture to those drives anymore. I just use them for storage and completed projects freeing up my internal drives. I have 3 SATA drives in my new editing computer. the original 250g that came with the machine and I bought 2 200gb drives for files and capture.
    Allen
    My web site features;
    China, China Railways and music.
    https://www.azagel.com
    Video site;
    https://www.asxvideo.com
