Activity › Forums › Adobe Premiere Pro › Video capture cards
  • Video capture cards
    Posted by Stephen Reber on June 11, 2008 at 5:11 am
    Hey all,
    I need a tad bit-o’ pro help. I am looking to transfer VHS video to DVD, via capturing the video on my rig, de-interlacing it in AE, and doing the final DVD authorizing in Encore. The problem is getting the VHS video into my computer. I have Adobe Premier CS3, have read tutorials and am now totally confused. Do you need a video capture card that is compatible with Premier (I currently have a Hauppauge PVR-150, and it is not), or just software that will record the video from the card?
    As for the mode of transfer, I have a DVD/VCR combo, it has the s-cables in back, and is compatible for the 2009 switch over. From what I understand, I can just plug the “out” s-cable on the DVD/VHS combo to the “in” s-cable port on my computer? Is this correct? I have been reading conflicting thoughts that I have to digitize the VHS video first through something like a DV-camcorder, others say you can just plug the VCR into your computer and you’re set.
    Basically I am looking for some advice, am I heading in the right direction? What might a be doing wrong (technically speaking)? Any advice on inexpensive video transfer cards that work with Adobe Premier CS3, that won’t kill me financially (I’m putting myself through grad school), and any thing that I might not know.
    Thanks-a-billion for any help anyone can give me.
    Best…
    Stephen =]
    Harm Millaard replied 18 years, 3 months ago 2 Members · 1 Reply
  • Harm Millaard
    June 12, 2008 at 12:20 am
    Ingest: Use the VHS player to play to a mini DV camera, use that camera as a pass through to capture via fire wire to the PC in DV quality with standard DV project settings.
    Do not deinterlace!!! From the original 240 LP vertical resolution (VHS quality) you throw away half by deinterlacing ending up with only 120 LP.
    Alternatively have a look at some Canopus ADVC solutions for analog ingest, like the 110.
    Hauppage is not usable with PP, you need fire wire for capturing.
    Harm Millaard
