Activity › Forums › Blackmagic Design › Video Blinking Issues with Burst In on Decklink HD Plus
  • Video Blinking Issues with Burst In on Decklink HD Plus
    Posted by Matt Geller on November 4, 2005 at 3:42 am
    I have a client here in Chicago who is mad about Blackmagic cards. So mad, in fact, that he insisted with going with the Decklink product into the HD domain. Since the post house in question has a multitude of modern and legacy decks, I suggested the HD Plus for its ability to accept genlock, and a Multibridge to convert legacy analog signals from the likes of a Beta SP deck.
    Unfortunately, I feel that might have been a bad consult: after exhaustive testing, asking for a replacement HD Plus card, and doing everthing but standing on our heads and crossing our fingers, we can’t avoid what seems to be a “feature” of the card (at least with the 5.1.2 drivers).
    In a nutshell, we are getting random, split-second loss of picture…”blinking” as the Blackmagic engineers are fond of calling it, whenever we feed a reliable genlock signal to the ref in of the HD Plus, and then view output from the card, whether viewing through SDI to a Panasonic SD930 DV50 deck, or through the ‘bridge to a Sony BVW-70 SP Deck, or just right out of the ‘bridge. And yes, we are feeding reliable (we tested other generators and cables) genlock to all three entities: Panasonic deck, Sony deck & the card. And yes, the Panasonic deck is set to external reference as is the Sony. We’ve even tried the cludgy Y out of the Multibridge through the reference of the deck into the Y in trick, to no avail.
    My client is on the edge of getting a you-know-what card, and I’m trying to salvage the deal. Any comments or ideas?
    The goods:
    Dual 2.5 G5, 2.5 GB RAM, 250GB drive
    HD Plus in Slot 4
    66Mhz Apple Fibre HBA in Slot 3 – both cables going to a 14 drive Xraid in RAID 50.
    Slot 2 empty
    OS 10.4.3, QT 7.0.3, FCP 5.0.3, BMD 5.1.2
    Panasonic SD930 DV50 deck with SDI
    Sony BVW-70 Beta SP Deck
    SDI OUT of ‘bridge goes to SDI IN on card
    SDI OUT of card goes to SD930 Deck
    SDI OUT of SD930 Deck goes to in on ‘bridge
    SP deck component and audio is interconnected to ‘bridge
    But even if we isolate to the ‘bridge, without the SD930, we still get the issue.
    And, if we take the ‘bridge out, and hook the HD Plus to the SD930, and feed the card genlock, it happens as well. (And yes, we read the doc on the BMD website and are feeding the SD930 external sync and we changed the menu setting for it to ref the external sync).
    Matt Geller
    THETECHTHERAPIST
    Full Service Consulting & Integration | Proactive & Reactive Maintenance
    Xsan Integration Specialists | Certified Trainer for Apple Pro Apps & Boris Products
    https://thetechtherapist.com
    Matt Dowling replied 20 years, 10 months ago 5 Members · 6 Replies
  • Jeff Bernstein
    November 4, 2005 at 5:03 am
    Matt,
    Have you tried removing sync just for $hits and giggles?
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
  • Matt Geller
    November 4, 2005 at 12:38 pm
    [Jeff Bernstein] “Have you tried removing sync just for $hits and giggles?”
    Removing the sync removes the blinking, no doubt, but in time, the pictures drift. Ya need sync if you have an analog deck…
    Matt Geller
    THETECHTHERAPIST
  • Kaspar Kallas
    November 4, 2005 at 6:15 pm
    I actually get the blink when there is no sync as well 😉
    Usually reboot fixes this for few hours – but not always
    -Kaspar
  • Matt Dowling
    November 7, 2005 at 1:26 am
    HI Matt,
    We are checking this out today for you – will get back to you ASAP.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Neil Sadwelkar
    November 7, 2005 at 3:37 am
    This blinking problem was reported by me as well. For the HDPlus.
    In my facility, we have two HDPlus with ref not connected as this blinking issue refuses to go away. Some driver release fixes it for some time, and then a new driver breaks it.
    Its been this way from Drivers 4.x till 4.8.1.
    The ver 5.0 and 5.1 were supposed to have fixed this. But we haven’t upgraded yet so I cannot be sure. The downside of not connecting ref is we can make DigiBeta and DV dumps, but not analog Beta as these tend to drift if no ref is connected.
    Neil
  • Matt Dowling
    November 7, 2005 at 7:15 am
    Hi guys,
    Below is a link to a build which i think will solve your problem.
    https://www.blackmagic-design.com/downloads/software/seed/DeckLink_Macintosh_5.1.2e1.zip
    Try this and please let me know how it goes.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
