Activity › Forums › Apple Final Cut Pro Legacy › video blackout during training
Posted by Scott Maida on January 20, 2011 at 5:11 pmI am following the training DVD that came with the fcp and suddenly, I can’t see any video. No offline warning and I closed the program and reopened.
Jeff Greenberg replied 15 years, 7 months ago 3 Members · 4 Replies -
Liam Ward
January 20, 2011 at 5:30 pmAre you saying that you can no longer see video in fcp? Or on whatever you were viewing your training DVD.
If it is FCP – Go up to the VIEW Menu and make sure you didn’t accidentally hit the shortcut to ‘WIREFRAME’ Should be set to either IMAGE or IMAGE + WIREFRAME depending on your preferences.
Liam.
Liam Ward
Sinking Ship Entertainment -
Scott Maida
January 20, 2011 at 7:14 pmI accidently discovered that but now I KNOW the way out of blackness.
however, now I have a green circle with a check in it.
meanwhile my DVD training continues… I’m a producer so I’m a little slow. -
Liam Ward
January 20, 2011 at 9:07 pmHey Scott,
The green check is letting you know that your luma levels are safe for broadcast. Turn it off by going to:
View Menu —-> Range Check —-> Off
Liam.
Liam Ward
Jeff Greenberg
January 21, 2011 at 3:11 pmYou’ve hit “UNDO” as if you were on Windows.
CNTRL Z adds/removes the luma range check
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
