Activity Forums Apple Final Cut Pro Legacy Video Bitrate Too High
  • Video Bitrate Too High
    Posted by Larry Lawfer on August 29, 2005 at 5:45 pm
    Yesterday, no problem today I can’t seem to get the Studio Pro 3 to build the files. The files are a total of 1.7GB, not to big. I have trashed the preferences and rebuilt. Is there any suggestions you might have. Since this is a DVD issue I am not sure if I am asking on the right forum. Thanks for any assistance to this quagmire.
    David Bogie replied 20 years, 9 months ago 2 Members · 1 Reply
  • David Bogie
    August 29, 2005 at 6:20 pm
    Check the apple.com forums, too.
    This is an all-too-common issue with DVDSP2 and 3. Bit budgeting should be automated, or at least user-configurable, but it’s not. It’s a stupid and manual process and requires the user to make esoteric choices none of us understand till we’ve screwed them up dozens of times. This has nothing to do with file size. It’s all about playing back the file and you are limited not to a computer performance but to the DVD Spec written 20 years ago.
    The problem is that audio and video combined are your total bandwidth and you have no control over audio. You must set your video bit rate not to exceed about 6.5. That leaves you about 2.5 for your audio bandwidth. You must use the APack encoder (itself a marvel of stupid non-Macintosh interface design) to process your audio separately from the video. Then bring the new audio track into your DVDSP project and replace the original audio with the new track. APack creates a full fidelity compressed file that is remarkably compact and requires only about 1/10th the bandwdith of conventional MPEG2 audio.
    DVDSP4 rocks, upgrade if you plan to try to make money with DVDs.
    bogiesan
