Activity Forums DVD Authoring Video Bitrate Too High
  • Video Bitrate Too High
    Posted by Larry Lawfer on August 29, 2005 at 5:59 pm
    Yesterday, no problem, today I can’t seem to get the Studio Pro 3 to build the files. The files are a total of 1.7GB, not too big. I have trashed the preferences and rebuilt. Is there any suggestions you might have. Thanks for any assistance to this quagmire.
    Larry Lawfer replied 21 years ago 3 Members · 6 Replies
  • Bill Stephan
    August 29, 2005 at 10:27 pm
    What bit rate did you encode at? The file size is irrelevant.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Larry Lawfer
    August 29, 2005 at 10:42 pm
    I don’t know the rate, in my preferences I have it set for a minimal of 4 with a max of 8. But it is confusing. In the DVD there are 6 videos and a slide show. It chokes on one of them. When I moved the videos around in their order it went through everything until it got to this video. All the other videos were output the same way. I have been experimenting all day with no luck. I am using the preset HQ 60 min variety. I have been trying to dumb down this particular video–smaller .ipr’s out of Live
    Type. Is any of this helpful to ascertain some work around. Thanks for your thoughts and valuable experience.
  • Noah Kadner
    August 30, 2005 at 12:16 am
    The LiveType ipr file size does not have a bearing on the DVD bitrate. Have a peek through the manual regarding Compressor and MPEG-2 creation. You need to lower the bitrate setting of the video causing the error. I’d suggest keeping the max well below 8Mbps.
    Noah
  • Bill Stephan
    August 30, 2005 at 4:01 pm
    If your encode is staying up ariund 8Mbps and you used PCM audio, your total bitrate is at the max for DVD, which is way too high to play successfully off a DVD-R.
    Bill Stephan
    USA Studios
    New York City
  • Larry Lawfer
    August 30, 2005 at 4:39 pm
    I have reset the droplet lower. I have only been working on the one video within the DVD where the build is choking. I am about to build the newest iteration. I am making a mistake to only be working on the one video since it is the one that chokes the build, or should I be redoing all of them? Thanks for your help
  • Larry Lawfer
    August 30, 2005 at 6:08 pm
    The problem was in Compressor and Bill lead the way to new thinking about the problem. I had to go back into Compressor and reset down (ever so slightly) my encode for the Mpeg-2 file 7.1 down to 6.7. It worked. I left Audio as it was and I am back in action. Thanks to those you responded.
