Activity Forums Maxon Cinema 4D video as texture error
  • video as texture error
    Posted by Abel Jimenez on March 2, 2010 at 7:24 pm
    Hi, i am having tons of problems, in my animation various objects have video playing on them, but when i create a texture with a video file it does not move, and when i try to render i get a “Texture Error” message.
    i am exporting the video from FCP and have tried several different exports, and i still get the same error massage.
    please help.
    thank you…
    Nolan Scott replied 16 years, 6 months ago 2 Members · 3 Replies
  • Nolan Scott
    March 2, 2010 at 9:14 pm
    What codec and resolution are you using out of Final Cut…?
    (does the resolution fit your object sizes in Cinema 4D…?)
    In Cinema 4D put your movies and textures into a texture-path Cinema can find…
    (open Cinema’s Preferences / Texture Paths / select your Path..)
    Regarding playback in the Viewport / in the Material in the Attributes-Manager
    open the Editor Tab and check Animate Preview…
    Otherwise use a JPG-Image-Sequence as your Texture, that might improve
    playback-speed in the Viewport considerably…
    Regards
    Nolan
  • Abel Jimenez
    March 2, 2010 at 9:40 pm
    Hi, i’ve am using several since i can’t get the one to work, i set the path and it still gibing me a texture error when i start to render, i figure that cinema 4D 11.5 should handle most codecs. bur i am trying to find the one that does not give me that error.
    Editor tip for playback works great, thank you very much for your help.
    i did not know it was so hard to incorporate video in to the animation
  • Nolan Scott
    March 3, 2010 at 2:20 am
    Well, this seems to be an “issue” with Cinema 4D 11.5…
    I am still using R 11.0 with Snow Leopard and have not encountered such problems…
    https://forums.cgsociety.org/showthread.php?f=47&t=830671&highlight=texture+error
    Regards
    Nolan
