Activity Forums Apple Final Cut Pro Legacy video and still images in same sequence
  • video and still images in same sequence
    Posted by Eric Holzapfel on July 31, 2010 at 12:24 am
    Hello All,
    I am going to start a project that uses video and stills. The video is 1280×720 HD. I plan to output to
    DVD (so no “HD”, but it will be 16×9 aspect ratio). Can I combine video and still images in an FCP sequence? I have worked with video only, and still images only, etc. Any tips on this will be helpful.
    eric
    Eric Holzapfel replied 16 years, 1 month ago 2 Members · 2 Replies
  • Chris Tompkins
    July 31, 2010 at 2:56 pm
    Yes, of course you can.
    Prep your stills b/4 importing.
    Use RGB, 72 dpi, about 2000pixels on the long side if you want to create moves on them. Make them PNG or tif but can also use jpeg, psd.
    Capture in HD
    Edit in HD
    Export “Current Settings” making a ref file.
    Drop the ref file into Compressor choose NTSC DVD SD 16X9
    Chris Tompkins
    Video Atlanta
  • Eric Holzapfel
    August 3, 2010 at 11:49 pm
    Hello Chris,
    Thanks for the info.
    Eric
