Activity › Forums › Adobe Premiere Pro › Video and audio timeline doesn’t scroll vertically (see picture)
Posted by Duke Sweden on February 7, 2016 at 2:54 amThis has been going on for a while now, but the scrolls on the right side of the timeline for video and audio doesn’t scroll. I have to reduce the size of my program monitor to be able to see all of my layers, which is starting to get ponderous. Check out the attached picture.
Is there anyway to get that function back other than reinstalling Premiere Pro?
Peter Garaway replied 10 years, 6 months ago 3 Members · 11 Replies -
Tero Ahlfors
February 7, 2016 at 8:43 amHow exactly doesn’t it work? Click and hold in the middle of the bar and drag up and down? Try to trash your preferences.
Duke Sweden
February 7, 2016 at 9:54 amThere’s nowhere to click. Either the top and bottom tabs, or the space in the middle. Nothing moves. It’s like trying to click on the image I attached. It behaves the same way in “real life”.
I never set any preferences so I don’t think that will help but I’ll look around for anything that says “Disable Scroll Bars” and uncheck it 😉
Thanks for responding though. Cheers. -
Duke Sweden
February 7, 2016 at 10:57 pmUPDATE: Well, it seems if I click and drag, not on the top or bottom “button” but in the sliding area, it will raise or lower the layers, but it’s so delicate if I click too hard it goes from top to bottom with no scrolling. Just as irritating! What’s the deal here!?!
Tero Ahlfors
February 8, 2016 at 5:09 amIf you hover over the video or audio track part of the timeline you should be able to scroll with the mouse scrollwheel too. If you have a second monitor you could use that for playback to get more space for tools.
Peter Garaway
February 11, 2016 at 6:51 pmHi Duke,
This video from PeachPit provides a good illustrations of the Timeline controls. Hope this is helpful!
https://www.youtube.com/watch?v=jjuEOE_8ndY
Best,
Peter Garaway
Adobe
Premiere Pro -
Duke Sweden
February 11, 2016 at 7:33 pmThanks, fellas.
Tero, if I place my cursor over the timeline it scrolls left to right, not up and down. I know how to scroll left to right and expand and shrink the timeline. That’s not my problem. My problem is scrolling up and down. As I said in my last post I can do it now by clicking and dragging on the area between the scrolling buttons, on the right (see image above), but it’s so touchy it’s really hard to scroll to the track I want to work on.Peter, thanks for the video but as you can see, my scroll bar looks nothing like the one in the video. That one has those 3 bars to better “grip” the slider, also, if you expand the track a space shows up between the up and down buttons. In my image above it’s just a flat image, no scroll bar, as you can see.
Peter Garaway
February 11, 2016 at 8:06 pmTry the following. Place your mouse over the track header for the layer you want to resize. Once you mouse is over the track, scroll up and down using your mouse wheel or trackpad to expend or decrease the size. You can hold down the Cmd (Mac) or Ctrl (PC) key as your doing it to make smaller increments. See the attached image for where you want to place your mouse. Let us know how that goes.
Peter Garaway
Adobe
Premiere Pro -
Duke Sweden
February 11, 2016 at 9:50 pmPeter, that’s not what I’m talking about. I know how to do that. Look at the image I included in my original post. Inside the red square. THOSE scrollbars is what I’m talking about. The up/down “buttons” are useless, I have to click between them and drag up and down but the space is so small it’s almost impossible to scroll exactly where I want to go. If, for example, I have 6 video tracks, and 4-6 are showing, and I want to scroll down so 3 and 4 are showing, it scrolls all the way down to tracks 1-3 no matter how slightly I drag the mouse.
I never had this problem before the last 2-3 updates, I’m almost positive.
Peter Garaway
February 11, 2016 at 11:01 pmSorry for the confusion Duke. I now understand what your referring to unfortunately I’m not seeing the issue though. That definitely sounds like you got the software into a bad state. Trashing prefs or reinstall might be the other option that I could think of.
Here’s a link to a screen recording that shows how Premiere is working for me using version 9.2. I personally like using my mouse wheel or trackpad to scroll in and resize the Timeline.
Do you find the scroll bars provide you controls you need that the mouse wheel or trackpad do not?
Peter Garaway
Adobe
Premiere Pro -
Duke Sweden
February 11, 2016 at 11:10 pmAs you can see the mouse wheel is only enlarging the track. The cursor then goes over to the scroll bar to go up or down. THAT…is the problem I’m having, not enlarging the height of individual tracks.
