Activity Forums Live Events & Streaming video and audio for a live concert
  • video and audio for a live concert
    Posted by Mitch Seekins on March 15, 2011 at 4:37 am
    Can anyone tell what I would need to accomlish this: I have a live show in which I need to project 1 video feed to a screen, and then send up to 6 separate audio channels to the front of house and monitor board. is the a software program that and I can do this with? I need to run this off a pc laptop and a m-audio usb interface. any ideas? I also own Media Composer 5 as an editing suite (not sure if that helps but I thought I’d mention it) I am budget restrained as its a very small show.
    Help!
    Thomas Leong replied 15 years, 5 months ago 2 Members · 1 Reply
  • Thomas Leong
    March 18, 2011 at 11:34 am
    Does your M-audio USB unit have 6 audio outputs and ASIO driver?
    If yes, then a software that can use the ASIO driver can send the audio out through the M-audio and you have your six separate audio channels. Obviously the same software should be able to send out one video channel at the same time.
    Check out VJ software, depending on Windows or Mac –
    MX Wendler
    Module 8 (Mac)
    Resolume
    Archaos
    or try demos where available from this list –
    https://www.audiovisualizers.com/toolshak/vjprgpix/softmain.htm
    good luck!
    Thomas Leong
