Activity › Forums › Adobe After Effects › Video along a Path?
Video along a Path?
Posted by Fran Zine on February 19, 2010 at 9:47 amHi
Does anybody know, how I can gear a video along a round path?
I will let the video circling along the path.can somebody help me?
Greetings from Germany
Joey Foreman replied 16 years, 6 months ago 3 Members · 2 Replies -
Michael Szalapski
February 19, 2010 at 2:49 pmCreate a circular motion path.
You will find this page and all of the accompanying links to be extremely helpful.
This page is mentioned in the link I just mentioned, but I wanted to call special attention to it.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Joey Foreman
February 19, 2010 at 3:00 pm1. Make your layer a 3d layer.
2. Set a keyframe for Y Rotation.
3. Go to a top view, grab the Pan Behind tool, and pull the anchor point away from the video layer. For now just move it straight back in z-space, or straight up in the top view.
4. Go back to Active Camera view.
5. Let go of the Pan Behind tool…hit V.Now when you rotate the layer in Y, it does so around the anchor point.
If you want you can create a camera and put it in the same location as the video layer’s anchor point, so the layer is always rotating at a distance, if that’s what you want.
One problem, though, with this approach is that you can no longer rotate that layer on its own axis.
So go back to step one. Forget the keyframe for Y.
Instead of moving the layer’s anchor point, create a new Null object, make it 3d, and move it away in z space. Now parent the video layer to the Null.
Now rotate the Null on its Y axis.
Same effect, but you can now rotate the video layer independently, if that’s what you want.
