Activity Forums Apple Final Cut Pro Legacy VIDEO 23.98fps, AUDIO 25fps – DOESN’T SYNC
  • VIDEO 23.98fps, AUDIO 25fps – DOESN’T SYNC
    Posted by Karlo Gorup on February 23, 2015 at 5:37 pm
    Hello!
    I have been working on a project entirely shot in 25fps. Recently, I got some additional material shot in 23.98fps by mistake.
    I managed to conform the video material to 25fps using Cinema Tools, but the audio, which was shot separately, was shot for 25fps.
    So, when I try to sync the conformed 25fps video and original audio, after few seconds video and audio start to fall out of sync.
    I read somewhere that if I stretch audio by 4%, I will be able to sync it properly, but that does not work…
    Does anyone know how to solve this problem?
    Michael Gissing replied 11 years, 7 months ago 2 Members · 1 Reply
  • Michael Gissing
    February 23, 2015 at 10:01 pm
    Firstly does the audio have timecode (ie: broadcast wav files with timecode metadata). Secondly 23.976 to 25 is 4.1% The .1% matters.
    So if you have changed the pictures to 25 and they run 4.1% faster, you need to correct the pitch as well as speed up the audio. Then when you load the new wav files in, make sure the FCP Easy Setup is on a 25fps preset, other wise FCP will stamp the wrong frame rate and cause drift.
    If you get that formula right then you should be good.
