Activity Forums Apple Final Cut Pro Legacy Vid Rate wrong after import
  • Vid Rate wrong after import
    Posted by Will In bangkok on August 10, 2005 at 6:41 am
    Enjoying the FCP learning curve,I have come across a problem today.I had exported a full rez 25fps QT of a job I finished at work yesterday,now when I import it into my 25fps sequence at home FCP wrongly tags the clip 29.97.Very awkward ‘cos play in the viewer goes out of sync.Obviously if I drop it in the timeline it reverts to the correct 25fps (but now I need a video render).I’ve checked user prefs,system settings and sequence settings and can’t find a problem.QT plays fine and the file is tagged at 25fps.
    Any ideas ?
    TIA,
    William Watts
    Set-up :
    FCP 5.02,G5,decklink pro,g-raid,QT7
    (export from DS Nitris 7.6 uncompressed QT using decklink codec)
    Will In bangkok replied 21 years, 1 month ago 1 Member · 1 Reply
  • Will In bangkok
    August 11, 2005 at 3:44 am
    Bump.
    (Cross-posted this to FCPUG Europe too,yet to find problem.)
