Activity › Forums › Maxon Cinema 4D › Vibrate tag
Vibrate tag
Posted by Gon Perdigao on November 30, 2009 at 4:11 pmHi there, is there a way to use the vibrate tag to make a “wiggle” on the glow texture?
Or is there a way to make a wiggle on a glow, that i can control with key frames?Thanks a lot
Adam Trachtenberg replied 16 years, 10 months ago 3 Members · 5 Replies -
Brian Jones
December 1, 2009 at 3:14 pmDo you want the Glow to move relative to the object, pulse or have noise?
Gon Perdigao
December 1, 2009 at 4:48 pmi want that the glow follow the object, and also to have a pulse.
Later on, i try turning on and off the glow, and giving keyframes, but the pulse is not natural.
Is there a way to make it like a light turning on, that it flashes some times and then is on all the time?
Thanks a lot
Adam Trachtenberg
December 1, 2009 at 6:01 pmHave you tried using the random and frequency parameters in the glow channel?
Gon Perdigao
December 1, 2009 at 6:05 pmyes, but the result is so smooth, that is not what i wanted (even using high values), the best result till now is turning on and off the glow, but i’d like to do it as i use to do in after efects, using a wiggle expression, is there a way?
Adam Trachtenberg
December 3, 2009 at 5:31 pmYou should reduce — not increase — the period setting to get a more chaotic look.
If you want to go another route you could create an expresso and use a noise node to drive the glob parameters through a range mapper — but that’s essentially the same thing as using the settings in the glow channel (except it gives you the ability to affect size as well as brightness).
