Activity Forums VEGAS Pro VHS transfer!
  • VHS transfer!
    Posted by Allan Boes on September 14, 2011 at 9:51 pm
    At the moment i’m using a chep usb thing, but it only works with 1 program(PowerDirector) and only have mpeg2 as a format choice.
    So I was thinking??
    Whats the best way to Transfer video tapes to your computer? And what device should I use? (dazzle,tv-card,or ?)
    Allan Boes!!!
    Working in Vegas pro 10 and Adobe photoshop CS5
    Ted Snow replied 15 years ago 8 Members · 12 Replies
  • 12 Replies
  • Stephen Mann
    September 14, 2011 at 9:56 pm
    Your best device would be a Canopus AVDC-300 because it includes a time-base corrector (TBC).
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Allan Boes
    September 14, 2011 at 10:16 pm
    Hey Steve
    I looks great 🙂
    But as my budget would say, is there any good products in the lower price range:)
    Allan Boes!!!
  • Mike Kujbida
    September 14, 2011 at 10:35 pm
    Grass Valley makes 3 different models of consumer analog to digital converters, the ADVC55 ($165.00), the ADVC110 ($220.00) and the ADVC300 ($400.00).
    All prices are from B&H.
    The 300 is the best but check out the other two since budget is a consideration.
  • John Rofrano
    September 15, 2011 at 12:37 am
    Let me be the third to recommend the Canopus ADVC line. I use the ADVC300 but as Mike said, if the budget is tight, go for the ADVC55. The important thing is to not use cheap converters like the Dazzle, etc. you will regret it. Conversion is not the place to skimp. It will be a big factor in your final quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nigel O’neill
    September 15, 2011 at 3:07 am
    If you still have an old DV camera lying around, you can try this:
    Using a component video cable, I hook up my VHS player to my old DV camera that supports pass-through straight to firewire. I then hit play on the VHS player and manually hit record in the Vegas capture utility.
  • Neal Barlow
    September 15, 2011 at 3:59 am
    Just to add one more log to the fire, I use A Sony GVD-200 video walkman. It’s lets me transfer 8mm tapes for clients, and then also has analog pass through. It has a TBC built in; however they run about $600 new right now.
    For what it is worth,
    Neal Barlow
    Owner and Original Man
    TWO MAN MOVIES
    twomanmovies.com
    The Cult Classic Returns in ZOMBIES DURING THIRD PERIOD: AGAIN
  • Steven Quan
    September 15, 2011 at 6:52 am
    If this component video to DV cam works it would be absolutely ingenious and worthy of buying a DV cam by itself.
  • Allan Boes
    September 15, 2011 at 9:25 am
    Thanks! As always, for all the great answers.
    Allan Boes!!!
  • Mike Kujbida
    September 15, 2011 at 11:43 am
    [Nigel O'Neill] “Using a component video cable…”
    Nigel, I’m pretty sure you mean a composite video cable (red and white for audio and yellow for video) as component would be 5 separate cables (3 for video and 2 for audio) and this is what a lot of consumer DV Cams had on them.
    Y/C (i.e S-video) is even better if your camcorder & VHS player have this option.
  • Nigel O’neill
    September 15, 2011 at 12:27 pm
    Thanks Mike
    I did mean component video – that’s what I get for reading and responding to the forum during siesta time.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
