Activity Forums VEGAS Pro VHS to Vegas question
  • Graham Bernard
    September 14, 2009 at 7:14 pm
    You’ll need an AV to DV covertor. You got? Most DV Camcorders allow for “Pass through”. Once you have this set up, through a firewire connection, Vegas’s Capture Program will recognize your signal. Make sure you have NOT engaged any DV-Control in Video Capture program.
    So it’s:
    VCR AV out > AV signal to AV:DV covertor (camcorder pass through) using whatever AV cabling is allowed > Firewire IEEE 1394 cable to your firewire input on your PC.
    Grazie
