Activity Forums Apple Final Cut Pro Legacy VHS to Final Cut
  • VHS to Final Cut
    Posted by Thomas Morter-laing on July 15, 2010 at 7:52 am
    Hello all, really simple- what’s the ChEAPEST way to get stuff from a VHS tape to a computer? I don’t have anything otherthan a VhS player, an iMac 27 i5 and that’s it. What do I do?
    Tom Morter-Laing
    Certified Apple Product Proffessional, 2010
    Production Assistant, Grace Productions
    Degree; TV Production
    Micah Mcdowell replied 16 years, 2 months ago 4 Members · 3 Replies
  • Peter Brewer
    July 15, 2010 at 8:18 am
  • Shane Ross
    July 15, 2010 at 8:31 am
    That captures to H.264. It will need to be converted to an editable codec after you capture it if you use that.
    The best, cheapest way would be to route it through a DV camera (if you have one). if not, then get the Canopus ADVC-110 analog to DV converter. Then use the DV/NTSC Easy setup…
    Shane
  • Micah Mcdowell
    July 15, 2010 at 3:04 pm
    Just a note; I’ve got a Canopus ADVC-110 and it’s always been very finicky; I also have an ADVC-55 and it’s more reliable, plus it’s cheaper. Get the ADVC-55 as long as you don’t need to output back to analog or get around Macrovision.
