Activity Forums Compression Techniques VHS to DVD over 3 hours per tape?
  • VHS to DVD over 3 hours per tape?
    Posted by Olly Lawer on October 14, 2010 at 6:40 pm
    I need to convert 14 VHS tapes to DVD for a client. They are over 3 hours on each tape.
    Are there DVDs that will hold 4 hours of footage?
    What is the cheapest, more time effective and best quality way of converting them?
    Only have FCP (no VCR or DVD recorder – apart from on the Mac).
    Kind regards,
    Olly Lawer
    Rich Rubasch replied 15 years, 11 months ago 3 Members · 2 Replies
  • Brad Elliott
    October 14, 2010 at 7:27 pm
    If someone put more than 2 hours on a VHS tape quality probably wasn’t their biggest concern.
    Putting more than 2 hours of video on a DVD-5 will only result in quality loss but you could get it on a dual-layer disc.
    Some players are picky about how well they will consistently play DL DVD-+R media. Unless the computer drive is recent a lot of drives can have issues with DL media.
    You could also author and build the DVD non-DL in DSP and have Toast compress it to fit on the DVD-5.
    I would consider buying a DVD-R recorder. It will save you a ton of compression time and many potential headaches. Medium quality ones aren’t that expensive.
  • Rich Rubasch
    October 15, 2010 at 9:52 pm
    Sony DVD Recorder….it has a 3-hour and even up to 6 hour record to a regular DVD. 3 hour encode actually looks pretty good and you don’t have to tie up an edit bay.
    Send the S-video signal from the VHS to the recorder and let ‘er rip.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
