Activity Forums Apple Final Cut Pro Legacy VHS to DV conversion
  • VHS to DV conversion
    Posted by Gcode9 on July 4, 2005 at 2:17 pm
    I’m attempting to convert VHS footage to Mini-DV for editing in FCP HD. The problem I’m running into is actually getting the VHS to DV conversion. I’ve attempted going from a stand alone VCR and also from my TV/VCR Combo deck. I’m only getting a blank blue monitor ont the camcorder while the footage from the VCR plays. What the hell am I doing here. For Pete’s sake someone help me pleaaassseee!!! Advise, comments, critiques, verbal discipline, anything that will make sense in getting this issue address.
    Thanks.
    17 PB
    FCP HD
    Sony Mini-DV Handycam w/i-link, a/v, s-video outlets
    Toshiba TV/VCR Combo w/ AV line-in
    Matthew Brunn replied 21 years, 2 months ago 3 Members · 2 Replies
  • Captain Mench
    July 4, 2005 at 2:22 pm
    Is your camera in VTR mode? Are you sure you have the VCR set up right? Cables going from the out?
    What type of DV camera are you using?
    CaptM
  • Matthew Brunn
    July 4, 2005 at 3:23 pm
    Some cameras do not have the ability to record from anolog. There should be a step by step in your owners manual for the camera. If you are trying to pass the signal through the camera directly to FCP, your camera may not allow this. Agian, check your owners manual.
