Activity › Forums › Adobe Premiere Pro › VHS to Blu-Ray H264 1080i or Mpeg2?
  • VHS to Blu-Ray H264 1080i or Mpeg2?
    Posted by Eric Balboa on January 26, 2014 at 2:55 pm
    I’m capturing VHS via the Canopus advc 300 in the dv codec. Each 2-3 hour tape needs to go on it’s own blu ray disc. Would you recommend transcoding to Mpeg2 blu ray or h264 blu ray in 1080i?
    I’ve done a couple with the Mpeg2 setting at “high quality” and the file size is rather small (only about 5-6gb on a 25 gb disc) as the default bitrate is set at 5.
    Should I stick with Mpeg2 and manually bump the bitrate up to 10 or even 15, or should I just use h264 1080i with a target bitrate of about 25?
    Richard Knight replied 12 years, 8 months ago 3 Members · 5 Replies
  • Richard Knight
    January 26, 2014 at 3:57 pm
    Why are you encoding a SD VHS tape in to a HD format, just burn as a dvd.
  • Eric Balboa
    January 26, 2014 at 4:04 pm
    The customer requested Blu-Ray.
  • Ann Bens
    January 26, 2014 at 4:05 pm
    Stick to mpeg2-dvd for DVD.
    You could advice the customer that VHS in HD resolution will never look good.
    You can burn mpeg2-dvd to BD if you need the disk space.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Eric Balboa
    January 26, 2014 at 4:22 pm
    My options are:
    1) Export in standard Mpeg2 DVD settings (CBR or 2 pass with a target bitrate of 6) and burn to blu ray.
    2) Export Mpeg2 Blu-Ray high quality and manually bump up the bitrate to 10 or 15 (although I’m a bit concerned this setting could choke out the customers Blu Ray player).
    3) Export H264 Blu-Ray 1080i.
    Disc space is not an issue as only 2-3 hours of footage are going on each Blu-Ray disc, and I want the finished product to look as good as possible (for VHS).
    I suppose I could try all 3 and see which looks best, but the encode times would be tremendous.
  • Richard Knight
    January 26, 2014 at 4:36 pm
    Option 1, you could up the bitrate to 7.
