Activity › Forums › AJA Video Systems › VHS capture with LH way out of sync
  • VHS capture with LH way out of sync
    Posted by David Roth weiss on July 18, 2007 at 4:29 pm
    I had to capture some VHS without TC for the first time using my Kona LH via analogue composite — it is way out of sync after capture. Used Kona DV codec, uncontrollable device, and set the Kona control panel to composite. Didn’t seem that anything else was necessary. Is there anything special I should have done?
    THNX
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    Jeremy Garchow replied 19 years, 2 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    July 18, 2007 at 4:31 pm
    What’s your ref set to in the Control Panel?
  • David Roth weiss
    July 18, 2007 at 4:38 pm
    Jeeze Jeremy, that was a mighty fast response. Your caffiene uptake must be optimized this morning…
    The ref was set for Free Run, probably should have been set for Video In huh?
    THNX
    David Roth Weiss
    Los Angeles
  • Jeremy Garchow
    July 18, 2007 at 4:50 pm
    Yes, I would toggle that and see what you get.
