Activity Forums Apple Final Cut Pro Legacy VHS Capture questions
  • VHS Capture questions
    Posted by Joseph Hung on August 6, 2012 at 9:51 pm
    Hello fellow cows,
    I’ve been reading posts on this topic and very informative, but not helpful for my case.
    Captured some clips from an old VHS tape. Consumer VHS player to AVTools Timebase Corrector to BMD Intensity Pro card, all via FCP7. RCA cables were used as I don’t have any other options for this specific hardware setup. Digital files are ProRes 422. Without the TBC I couldn’t get any good video or audio at all. So I’ve made it half way it seems.
    In FCP, the TBC did it’s job for the most part to correct the errors and I was able to get .mov files that looked right in FCP. However, when I open the .mov in say Quicktime player or MPEG Streamclip, the timebase errors are there, ie. ghosting of frames, or a frame freezes and then stays superimposed for the length of the clip.
    In FCP, both the viewer and timeline, the clip plays back fine. What, technically, is FCP doing to correct the clip? When I look at the master clip outside of FCP in any other app the ghosting is all there. I’ve tried outputting a new .mov at current settings and codec, and the resulting .mov has the ghosting errors.
    I know that I don’t have the most professional equipment for video restoration, and did some reading up on this. In the end, is this something that needs to go to a proper facility? Will they be able to restore the video better than I?
    Any insight is appreciated,
    Joseph
    http://www.tulpapictures.com
    Twitter: @tulpapictures
    Facebook: http://www.facebook.com/tulpapictures
    Mac Pro 3.0 GHz 8-Core Intel Xeon (2,1) 16GB RAM
    Macbook Pro 2.3 GHz Intel Core i7 (8,2) 4 GB RAM
    OSX 10.6.8
    FCS3
    CS5.5
    Blackmagic Intensity Pro
    NVIDIA GeForce 8800 GT 1GB VRAM
    RocketRAID 4322 via dual MiniSAS
    ProAvio 8TB RAID 5 Dual Mini-SAS
    Panasonic Lumix GH2 (hacked), Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
    Joseph Hung replied 14 years, 1 month ago 3 Members · 4 Replies
  • Tom Matthies
    August 7, 2012 at 2:30 am
    Try looking at your video in FCP with the canvas set to 100% to see both fields. Are the problems showing up now? Maybe you’re only seeing one field and the problems are on the other fields?
    E=MC2+/-2db
  • Joseph Hung
    August 7, 2012 at 4:43 pm
    You were right. At 100% I can see the fields and the ghosting is there. “Fit to window” does not show these errors.
    So, what I did was drop the clips into the Timeline, added deinterlace filters to each, set it to Lower (even), render and output the files at current settings and now the clips play fine.
    I would love to know why this is? Why does FCP hide these issues at smaller viewing sizes? Deinterlacing the clips worked out, but maybe I don’t know enough about how deinterlacing actually works? I plan on doing more VHS captures, but the more I know the better I’ll be.
    Thanks for your help!
    Joseph
  • Joseph Owens
    August 7, 2012 at 8:12 pm
    [Joseph Hung] “Why does FCP hide these issues at smaller viewing sizes?”
    FCP only shows you one field in preview.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Joseph Hung
    August 7, 2012 at 11:26 pm
    Of course it does, dang it. Thanks for the help!
