Activity › Forums › Blackmagic Design › VGA into intensity pro
Posted by Elendill Elendill on August 1, 2011 at 8:46 amHi,
I am trying to capture laptop’s VGA output with an intensity pro.
I bought a VGA to Component cable but it doesn’t work.What should I do ?
Drake Hatfield replied 14 years, 10 months ago 4 Members · 4 Replies -
Bob Zelin
August 1, 2011 at 11:37 pmUnder $5000, and will work wonderfully.
There are cheaper solutions, but I want you to spend the $5000.
bob Zelin
Danny Hays
August 2, 2011 at 12:31 am -
Elendill Elendill
August 4, 2011 at 7:20 amI’ve found it :
MCAD – Audio Vidéo/Périphériques Vidéo 051231 – 80€
https://www.konektikpc.com/produits/Accessoires-Image/MCAD/MCAD-Audio-Video-Peripheriques-Video-Accessoires-Image-051231-2385524.aspx?mscssid={EB50C33A-07A2-46C7-93D3-E61CC52AB652}&referer=/catalogue/catProductList.asp&flNoRedirect=0&flPackageOnly=0&lbCategory=Accessoires+Image
Drake Hatfield
October 18, 2011 at 5:39 pmI have absolutely NO interest in spending $5000 on an adapter for the $150 card.
Elendill, did it work? I am still struggling to solve this issue myself. I purchased an Aluratek VGA to DVI/HDMI adapter… Insanely strong in terms of build quality, can’t get anything to my card! If you found a solution then I want to jump on that bandwagon.
Also, if it works for you, what frame rate and resolution are you capturing at?
