Activity Forums VEGAS Pro VFX question
  • VFX question
    Posted by Paul Gilmore on August 6, 2009 at 4:08 am
    I’m starting pre work on a short film. There is a scene where the actress is going crazy and seeing things that are not really there or happening. The scene calls for a shot of her looking at a wall as she suddenly sees a crack form along the wall out of nowhere. Is there anyway to make this happen using Vegas?
    Terry Esslinger replied 17 years ago 3 Members · 5 Replies
  • Terry Esslinger
    August 6, 2009 at 4:31 am
    Using Vegas alone it might be pretty hard. Unless you had a shot of a crack with a wall that you could key out. After effects would probably be the answer. I have it but haven’t had time to learn it yet.
  • Paul Gilmore
    August 6, 2009 at 4:33 am
    Can you import footage into vegas from AE?
  • Paul Gilmore
    I was told you couldn’t but I don’t see why that would be
  • John Gleason
    August 6, 2009 at 8:50 am
    I’ve added effects to a clip using AE, rendered it, then took that new video file and dropped it into Vegas. Not sure what other work flow you could do using AE.
  • Terry Esslinger
    August 6, 2009 at 9:27 pm
    Yup, thats the way.
