Activity Forums Panasonic Cameras VFR Cadence error
  • VFR Cadence error
    Posted by Sean Fine on June 20, 2006 at 9:11 pm
    Tryign to capture varicam footage via friewire shot at 24p with varicam onto FCP sytem. I am using G-raids. Anyway I have searched high and low for answers to this problem, but no one has a solution so i thought I would try again. Capturing footgae has become difficult and very time consuming. I constantly get errors on clips that say error with VFR cadence. This error stops my whole sytem fro capturing. I usually have to reboot or move on to another tape. From what i gather this is a 2:3 pulldown issue with starting and stoppign the camera. I have tried everything and as you can imagine with over 100 hours of footage to capture this has become a royal pain in the butt. I am using a 2ghz G5 dual processor with FCP HD. I also have a Kona LH card. If anyone has any suggestions please let me know. A solution could save me weeks worth of headaches and wasted time.
    Sean
    Gary Adcock replied 20 years, 3 months ago 3 Members · 2 Replies
  • John Sharaf
    June 21, 2006 at 12:35 am
    Sean,
    When I had this problem, I solved by importing through Kona card HD-SDI in and let the Kona card convert to DVPRO100 codec.
    JS
  • Gary Adcock
    June 21, 2006 at 2:00 am
    [Fine Productions] “ryign to capture varicam footage via friewire shot at 24p with varicam onto FCP sytem. I am using G-raids. I constantly get errors on clips that say error with VFR cadence. This error stops my whole sytem fro capturing. From what i gather this is a 2:3 pulldown issue with starting and stoppign the camera.”
    Cadence issues in FCP normally are a result of the pulldown pattern changing. Starting and stopping are one form, speed changes or speed ramping is another.
    TURN ON capture thru time code breaks in the Users settings FCP
    Stop trying to capture the entire tape as one file.
    Set in and out points on every clip you capture
    Capture at 59.94 and then run the file thru the software FRC.
    DO NOT use “Capture Now” because while FCP can determine the starting cadence- it cannot determine where to end without a fixed out point on for the capture.
    [Fine Productions] “I am using a 2ghz G5 dual processor with FCP HD. I also have a Kona LH card.”
    this is less of an issue in FCP v5 or as JS said — capture over HDSDI back to the DVCPROHD codec via the kona
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
