Activity Forums Adobe After Effects Very VERY basic question
  • Very VERY basic question
    Posted by Philrose on August 22, 2006 at 2:48 pm
    ‘Newbie’ doesn’t begin to cover me…
    I am using After Effects 5. How do I add text to a piece? Unbelievable, isn’t it? I know but I can’t find a Text tool button and the help files just assume you can do it.
    Your shamefacedly,
    Phil
    Phil Rose
    Photographer, Graphic Designer, Web Designer of sorts
    Michael Duff replied 20 years ago 3 Members · 4 Replies
  • Yarin Manes
    August 22, 2006 at 4:38 pm
    go to layer/new and add text layer then just type anything and press enter on your numeric keyboard,then it will also appear on the timeline for you to design.
  • Michael Duff
    August 23, 2006 at 4:11 am
    actually AE5 doesn’t have text layers. You need to make a solid (Ctrl-Y), then apply the effect “Basic Text” it should be near the bottom of the effects menu. There is also “Path text” which has some more options, and “number” which is good for animating countdowns or timecode.
  • Philrose
    August 23, 2006 at 5:17 pm
    Thanks a million for that. I must play about with it. So AE is not a good candidate for making Flash based websites featuring large amounts of text, I guess? Or is there a way around this?
    Thanks again,
    Phil
    Phil Rose
  • Michael Duff
    August 23, 2006 at 11:41 pm
    well I find AE is very good for animating text – but the problem is going to be how you get it into flash and keep a decent filesize….. because it will not be vector based like flash is….
