Activity › Forums › Apple Final Cut Pro Legacy › Very strange warning
Posted by Rafael Amador on August 22, 2012 at 10:42 amA friend of mine sent me a pic of a warning he’s getting from FC.
i’ve never seen that before.
Any idea?Thanks.
rafa elRafael Amador replied 14 years ago 5 Members · 8 Replies -
David Eaks
August 22, 2012 at 11:58 amI think that pops up after restoring a project from the autosave vault and then hitting save.
John Christie
August 22, 2012 at 4:15 pmAgreed, I get it every time I restore a file from the vault and re-save it.
Rafael Amador
August 22, 2012 at 4:23 pmDavid & John,
Thanks for the answer.
I’ve never “restored” any project, but open directly the autosave files.
thanks for the help.
rafael -
Neil Ryan
August 23, 2012 at 1:59 amThat message can arise in a network environment with multiple edit suites, where projects are stored on a network location, and two suites have the same project open.
Rafael Amador
August 23, 2012 at 4:33 am[Neil Ryan] “That message can arise in a network environment with multiple edit suites, where projects are stored on a network location, and two suites have the same project open.”
yeap.
my friend thinks that somebody has been manipulating his project and may be with bad intentions.
do you know if there is anyway to see (in the System logs or in the network) which computer has accessed the Project?
rafael -
Anna Ingenthron
August 23, 2012 at 7:37 pmI’m not sure if there’s a way to do that, but if he’s concerned about that, he could change the permissions on his file (⌘i) so he’s the only one with read & write, and everyone else has read-only.
Neil Ryan
August 26, 2012 at 11:49 pmMy understanding is that you can’t see which user last used the project, however, if you are on a networked environment, he may be able to look at the various suites/users for their Autosave folders, to see who has had the project in use, and when.
Rafael Amador
August 27, 2012 at 1:44 am
