Activity › Forums › Apple Final Cut Pro Legacy › Very strange & scary, files go missing on time line
  • Very strange & scary, files go missing on time line
    Posted by Dog Food on October 30, 2006 at 10:35 pm
    FCP 5.0
    Power MAC G5
    DUAL 2.5 GHZ
    6GB RAM
    Well, I am done with primary editing and just putting the final touches on a 1 hour show for ESPN and poof.. clips are missing.. they just vanish. and then teturn and then vanish again.. sometimes it says “media file mississing” but themedia is there.. and other times it says the clip is there but it is missing…
    this is very weird.. It started last night around 12am.. I just stopped working and hoped it wuld go away (LOL)… and now I come back to the project and it is just a joke.. it’s not even presentable. I have seen this before but never so bad.. WHY DOES IT ALWAYS HAPPEN AT THE END OF A PROJECT!!!!
    any thoughts? what am I to do?
    of course I have chucked the preferences already.. NADA…
    another bizarre event.. when i try to reconnect the video in the time line it says it reconnects it.. but in actuality it just disconnects more clips…
    this is F%$# ed…
    any ANY AANNYY input would be appreciated.
    cheers
    Bret Williams replied 19 years, 11 months ago 6 Members · 9 Replies
  • 9 Replies
  • Bret Williams
    October 31, 2006 at 1:25 am
    Drives sleeping? Ejected CDs/DVDs with imported media?
    A hard drive that’s going bad fast. Seriously a possibility especially since you’ve seen it before. I’VE NEVER seen that before, but occasionally heard of something similar.
  • Jason Jenkins
    October 31, 2006 at 5:01 am
    I’ve been on a contract edit for the last two weeks (using their equipment) and stuff is constantly going offline. When I modify a Livetype or Motion file -5o% of the time it goes offline instead of updating in the timeline. There have been plenty of crashes, freezes and slowdowns as well. What a nightmare.
  • Bret Williams
    October 31, 2006 at 5:54 am
    How have you been updating the Motion file? You cannot, for example, leave the motion project open and just switch over to it and make adjustments and save. FCP will see that the file is different and make it off line. You have to get to the Motion project from FCP so that it is awaiting a change. You need to right click in the seq and choose to open in Motion/Livetype.
  • Jason Jenkins
    October 31, 2006 at 6:47 am
    I’ve been right clicking and choosing “open in editor”. Does the Motion project need to be closed before returning to FCP?
  • John Steventon
    October 31, 2006 at 8:23 am
    I’ve had something similar a couple of times (by the way, I don’t know how to fix it).
    Happily editing away, go into another project, come back, and half the media has gone. The difference between your and my situation though is that I can’t re-connect. When I select the offline clips, and choose re-connect, the window doesn’t even display the clips for me to reconnect.
    I can’t batch-capture just the clips on the timeline I need either (have you tried that as a fix?) – On my system, even if I choose ‘make clips independant – or if I go to media manager to make a sequence to let me only digitise the clips used – it still wants to take in the entire rushes relating to that clip.
    If you’re in rush – and it won’t re-connect properly, the only real thing you can do is a) Re-import the QT’s off your hard drive, and manually drop in each of the clips into where they’ve gone offline. B) If your system will let you, do a batch capture of the offline clips – get ’em bac k in that way – or, if you’re like me and FCP won’t let you – c) Export an EDL – import EDL, recature the clips your need – then as you lay each clip back onto the timeline, copy the old one so you can paste the attributes of any effects back into it.
    It’s interesting that others have this fault – I’d always been fobbed off with ‘it must be your system’. Good luck with it, I share your pain.
    John
    Success is merely a failiure to imagine more…
    G5 2.7Ghz, 4.5Gb ram, Blackmagic Decklink/multibridge, 5.6Tb Infortrend storage, FCP Studio 5.02, Makie MCU control, Yahama 5.1 surround, JVC DTV multi-format monitor, 2x23inch Apple monitors – and a partirdge on a pear tree.
  • Dog Food
    October 31, 2006 at 5:38 pm
    major progress last night…
    1. toss preferences
    2. repair permissions
    3. toss all rendered files..
    and then.. I dig into the “reconnect” process a little bit and find a file that has a different name than a 40 minute clip that is part of a “multi clip”.. BINGO..
    I do a manual “reconnect” and I get 90% of my my clips ONLINE.. anthing with “speed” modification was scrammbled and had to be replaced/redone.
    I will say this.. I have had a MAC since the first day they came out in 1984 ( I got it at Macy’s). Of the hundred + shows I have edited from start to end.. This is the fewest crashes I have ever had.. ONLY 1 CRASH… + this blunder.. (which was probably my fault)…. Normally with a project that is 1 hour long with 30 Video/audio layers I usually get at LEAST crash everyday… some time up to 10 crashes…
    Hats off to 5.0.1 and 10.4.8….. Now I am scared to death to upgrade to 5.1.1 (the disks are just sitting here)
    thanks for all your support GUYS!
    cheers
  • Seawild
    October 31, 2006 at 8:07 pm
    Hello,
    Sorry about this… But I forgot how to repair permissions.
    Did a search, but nothing obvious popped up.
    Thanks, Chris
  • Debe
    November 1, 2006 at 2:48 pm
    Repairing permissions is done in Disk Utility, which is usually located in [main hard drive]>Applications>Utilities>Disk Utility. Select the boot drive in the left column, and hit the “repair permissions” button at the bottom of the screen. Get coffee. It’ll take a few minutes.
    debe
  • Bret Williams
    November 2, 2006 at 4:38 am
    Making clips independant simply unlinks them from the clips in the bin. For example you could redig the clip in the bin and it could still be offline in the seq. Making them independent in no way makes them shorter or change their media start/stop points.
    To do that, you’d have to media manage the sequence.
