Activity Forums Apple Final Cut Pro Legacy Very strange bug- all clips in sequence with name of sequence
  • Very strange bug- all clips in sequence with name of sequence
    Posted by Samah Bennett on March 10, 2010 at 10:44 pm
    I have a very strange bug that is causing all of the clips in a sequence to have the name of the sequence.
    And when I try to do match frame, it just jumps the play head to one specific point in the sequence for no rhyme or reason.
    I think this might be a sign that the project file I’m working in might be corrupt.
    Any thoughts or insights on what might be causing this or how i could solve this very strange problem?
    Thanks.
    David Fortin replied 16 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Ben Holmes
    March 10, 2010 at 11:31 pm
    I’ve seen this. A reboot appeared to solve it – although I also subsequently trashed prefs just to be sure. The project was fine afterwards as far as I remember.
    It does make for an amusing looking timeline…
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Ben Insler
    March 10, 2010 at 11:32 pm
    I’ve heard about this before but not experienced it or heard of a fix.
    Sounds like a preferences issue. Trash em?
    If you start a new project and copy footage in from the timeline in question, does the same thing happen? Does it happen on another FCP system when opening the same project?
    Ben Insler
    Editor
    Telemark Films
  • Ben Holmes
    I’d also add that the system I was using was on FCP 7.0. Out of interest, what version are you running – have you upgraded to 7.0.1 yet?
    Edit Out Ltd
  • Tom Wolsky
    March 11, 2010 at 12:54 am
    Update to 7.0.1. Make sure there isn’t a freeze frame at the beginning of the sequence.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • David Fortin
    March 25, 2010 at 8:24 pm
    This just happened to me. Running 7.0.1.
    I shut down, rebooted and trashed preferences. Still all the same names.
    I did have a freeze frame as the first clip. So I got rid of that. But the names still were the same.
    So I trashed preferences again (after removing the freeze frame as the first clip), shut down, rebooted… no change.
    Has anyone else figured out how to get the clip names back?
    David
  • Tom Wolsky
    March 25, 2010 at 9:50 pm
    Removing the freeze frame won’t change the names back. You still have to redo the edit. Removing or replacing the freeze simply prevents it from happening.
    All the best,
    Tom
  • David Fortin
    March 25, 2010 at 10:34 pm
    OK. Thanks Tom.
    Because of some tight deadlines, I will have to continue as is.
    If I don’t re-edit, am I correct in thinking that the footage won’t re-connect if the files are taken offline?
    My RAID is pretty empty, so I can leave the footage on it for the time being.
    Thanks for getting back to me on this. Although it wasn’t too nice to have this freaky thing happen, it was great to search and find not only people who had the same problem, but others who had answers to it.
    I love this site.
    David
