Activity Forums VEGAS Pro Very slow rendering times?
  • Very slow rendering times?
    Posted by Brian Stolarski on May 14, 2013 at 7:08 pm
    So first off here are my computer specs,
    GTX 660TI
    i5 3750k @ 4.2GHZ
    8GB DDR3 Ram
    I record video’s using a program called OBS and i’m rendering in Sony vegas pro 12.0 64-bit.
    When trying to render a video that’s about 10 minutes it’s taking 2-3 hours. I’m trying to render the video to 720p.. why would my rendering times be so slow with my specs?
    Capt’n Brian replied 13 years, 4 months ago 5 Members · 5 Replies
  • Dave Osbun
    May 14, 2013 at 7:32 pm
    Please post your project settings and your render settings.
  • Brian Stolarski
    May 14, 2013 at 7:43 pm
    oops sorry, i’m rendering in windows media video V11(.wmv)
    Here are pictures of my project/rendering settings, as also the settings for my OBS.
    I have tried rendering in both 1080p and 720p and both give same rendering times.
  • John Rofrano
    May 14, 2013 at 8:54 pm
    Two things are wrong that I can see:
    (1) You are recording at 35 fps and rendering at 29.97 fps. That means a lot of frames are being blended together to go from 35 to 29.97 and your Core i5 is not the fastest CPU to be doing this with. Try Disable Resample on all of the events or record at 29.97. (or record and render at 30fps but don’t mix frame rates)
    (2) Your render template for 720p uses an aspect ratio of 1.3333 which is wrong. Your pixel aspect ratio should be 1.0000.
    Also WMV is the worst format to be rendering to becasue it’s not GPU accelerated and takes a lot of CPU. I would render to MainConcept AVC using the Internet HD 720p or 1080p template and enable CUDA in the template so that it takes advantage of your GTX 660 Ti GPU.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • David Alfredo
    May 14, 2013 at 9:21 pm
    [John Rofrano] “Also WMV is the worst format to be rendering to becasue it’s not GPU accelerated and takes a lot of CPU. I would render to MainConcept AVC using the Internet HD 720p or 1080p template and enable CUDA in the template so that it takes advantage of your GTX 660 Ti GPU.”
    a couple of comments, for Vegas to take advantage of the 6XX series GPU, latest Nvidia WHQL drivers are required, and the support for Vegas is in beta, so it’s a bit of hit or miss, using Sony AVC/MVC templates forces Vegas to use the 660 Ti, way quicker renders if you don’t mind AVC instead of Mainconcept.
  • Capt’n Brian
    May 15, 2013 at 12:09 am
    So this is what i ended up with my render after uploading it to youtube, https://www.youtube.com/watch?v=eWmxPuJS8H8&feature=youtu.be
    it looks quite bad..
