Activity › Forums › Sony Cameras › very slow export to QT from XDCAM EX timeline
  • very slow export to QT from XDCAM EX timeline
    Posted by Jim Watt on March 20, 2009 at 7:26 pm
    I have a one hour XDCAM EX program that I’m exporting to a self contained QT movie. The dialog box tells me it’s going to take 8 hours. In the past this same process normally takes less than an hour. Any ideas what the problem may be?
    Timeline is native XDCAM EX, set to pro res render
    Dual quad core Mac Pro/10 gigs ram/Video drive is apple raid (is a little full)/ Kona 3 card. FCS-2
    Thx for any suggestions…jw
    Craig Seeman replied 17 years, 6 months ago 3 Members · 3 Replies
  • Michael Slowe
    March 20, 2009 at 9:44 pm
    Very often the first time that is indicated is way longer than the job will actually take and then it sees sense and adjusts. Have you waited long enough for this to happen, it generally takes a few minutes. As you will know a Self Contained export takes far longer than a By Reference anyway.
    Michael Slowe
  • Jim Watt
    March 20, 2009 at 10:49 pm
    It started at 8 hours and actually took 2 and a half. I think maybe the reason it took so long is in this particular show I had a couple dozen mattes & masks, which I normally haven’t had in the past.
    thx…jw
    Producer/DP, HD series, “Discoveries…America”, “Discoveries…Ireland”, “Discoveries…Spain”,
    “Discoveries…Argentina”
  • Craig Seeman
    March 20, 2009 at 10:57 pm
    I don’t doubt if you had a complex show open, it saw that first and based the estimate on that.
