Activity Forums Adobe After Effects Expressions very sloooooow AE
  • Posted by Hamish Boyd on May 2, 2005 at 8:56 am
    Ok, I know my project has got quite big, but things are getting rediculous. I’ve heaps of pre comps an such, and things have slowed, but now when I simply create a new comp and place one layer of video, it takes literally around 20sec or more to bring up the frame. Every time I move along the timeline, it will take that long to find the next frame. I’ve had prjects this size before. So I’m not sure whats going on. I’m running 6.5 on a G5 with around 1500mg of ram.
    In anycase, its happening in the most simplest comps such as I discribed.
    Any ideas???
    Cheers
    Hamish Boyd replied 21 years ago 4 Members · 5 Replies
  • Filip Vandueren
    May 2, 2005 at 1:43 pm
    Are there any Expressions or a lot of Parenting going on ?
    Be sure to bake your expressions as soon as possible.
  • Hamish Boyd
    May 2, 2005 at 9:57 pm
    um yeah heaps. Spread throughout the project. Parenting, not expression though.
    What do you mean by bake your expressions?
    Cheers
  • David Johnson
    May 3, 2005 at 5:15 am
    If you have more than one comp window open, the synchronize preference can really slow things down. If you’re gettingthe spinning beachball a lot, that pref could be the culprit. I use a G5 at work and W2K at home and the Mac seems to have more trouble with the synchronize pref than I was use to so it took me a while to figure out what the problem was.
  • Andrew Yoole
    May 3, 2005 at 5:42 am
    Make sure you have installed the 6.5.1 patch. There’s an acknowledged slow-down bug in 6.5 which is fixed with the patch.
  • Hamish Boyd
    May 3, 2005 at 7:40 am
    Cool! that should help.
    thanks fellas, on to it now
    cheers
    hamish
