Activity Forums Adobe After Effects Very simple question, After Effects CS6
  • Very simple question, After Effects CS6
    Posted by Jack Owens on June 21, 2013 at 1:44 am
    I was watching a video on YouTube on how to make an explosion. However, the video is not very helpful as the guy doesn’t explain anything.
    The part I am stuck on is at 1 minute 22 seconds when he makes a “patch” of the texture of the ground, and then he covers up an object with it. After that, he copies an object and is able to make it appear and disappear.
    Here is the video: https://www.youtube.com/watch?v=qL1KkAfwflk
    Please help me guys!
    Jack Owens replied 13 years, 2 months ago 4 Members · 5 Replies
  • Jack Owens
    June 21, 2013 at 2:26 am
    The part of the video I don’t understand is at 1 minute, 22 seconds
  • John Cuevas
    June 21, 2013 at 2:57 am
    At 1:22, he duplicates the layer. On the duplicate he makes a box sized mask on some empty pavement and moves that over the box. You do this so when when you blow up the box, when the explosion is gone, nothing will be left.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • James Mccavana
    June 21, 2013 at 8:50 am
    He quickly duplicated the main layer (by selecting it on the timeline and pressing command+D), then pressed Q to activate the Rectangle Mask Tool and dragged out a mask on a bit of the ground on that duplicated layer.
    He then pressed V and moved that little rectangle selection of ground to cover the box.
    Hope that helped.
    Editor / After Effects
  • Todd Kopriva
    June 21, 2013 at 11:20 pm
    I recommend that you begin at the beginning and start here to learn After Effects: https://adobe.ly/bjBT3P
    After Effects team blog
  • Jack Owens
    June 23, 2013 at 2:56 am
    Thanks! That solves my question 🙂
