Activity › Forums › Boris FX › Very quick Boris Red speed ramp question
  • Very quick Boris Red speed ramp question
    Posted by Samuel Frazier on September 19, 2005 at 3:08 am
    I’m using Red as a filter inside FCP to speed up some clips. The footage is 10 bit uncompressed digibeta material on a 23.98p timeline (it’s film orginated and has had its pulldown removed).
    I know Red only renders in 8 bit with regards to color correction, etc. But if I use it as I explained, will my material be downgraded to 8 bit, or will it still be rendered as 10 bit?
    Sorry for the confusion, but thanks for any help!
    Samuel Frazier replied 21 years ago 3 Members · 4 Replies
  • Stephen L. noe
    September 19, 2005 at 5:00 am
    This is a very good question. Red’s stand alone engine will render 8 bit but when you’re inside of another program and using Red as a plugin, Red uses the render engine inside of the host app. At least it does in Liquid. I don’t know the answer but do your colors shift once rendered in tone when rendered?
  • Samuel Frazier
    September 20, 2005 at 1:00 pm
    Thanks for that. I didn’t know Red uses the render engine inside of the host app. I’m not sure what that means for workflows. I actually have not noticed any color shift using Red as a FCP filter. A friend did some work in Combustion ad gave it to me back at 23.98 Uncompressed 4:2:2. That file was significantly darker than the original, but I didn’t notice that kind of change when I used Combustion on another clip.
    So, can any educate us a little bit about how Boris works in other aps?
  • Christopher Wright
    September 21, 2005 at 7:05 am
    Red within FCP is only 8 bit. If you use the Boris continuum filters in After Effects and Combustion, most, but not all, filters will be rendered in 16 bit. (After Effects actually gives you a warning when the Boris filter can’t be rendered in 16 bit).
  • Samuel Frazier
    September 27, 2005 at 11:37 pm
    Very cool! Thank you for the help!
