Activity Forums Adobe After Effects very large image sequence
  • very large image sequence
    Posted by Vlad Patrulescu on September 8, 2009 at 7:19 pm
    Hi guys!
    i made a comp with some animation
    the canvas is huge, 5000/2440 px, i need it that big cause i m useing the animation as a 3d max animated map, and i wanted it very big for best quality in max.
    the thing is, when i m trying to export the image sequence via file/export/image sequence or render queue, it only exports the first frame. i belive its because of its big size since everithing else is rendered ok but i wanted some advice on what to do
    thanks!!
    Walter Soyka replied 16 years, 12 months ago 2 Members · 1 Reply
  • Walter Soyka
    September 8, 2009 at 8:45 pm
    After Effects can handle huge comps — up to 30,000 by 30,000 pixels.
    Perhaps your work area is accidentally set to only the first frame? In your timeline, go to the first frame you need and hit B. Go to the last frame you need, and hit N.
    Walter Soyka, Principal
    Keen Live, Inc.
    Presentation, Motion Graphics & Widescreen Design
    RenderBreak: A Blog on Innovation in Production
