Activity › Forums › Square Box CatDV › “Very General Query”
  • “Very General Query”
    Posted by Justin White on January 10, 2011 at 7:33 pm
    Anyone know of a way to keep this message, “Are you sure you want to perform query anyway?”, from opening every time I use the “Any Logging Field” when searching for footage? I’ve gone through the settings and manual countless times trying to find away to keep this from happening. It’s just getting alittle annoying when I’m trying to research footage and I only have one or two key words to help me in my search.
    Kevin Duggan replied 15 years, 8 months ago 3 Members · 3 Replies
  • Rolf Howarth
    January 10, 2011 at 9:41 pm
    No sorry, since 8.1.7 I’m afraid it always displays that warning if you search for “any field” contains something, with no other query terms to narrow down the search. If you have a large database it can take a long time to do a query like that because it can’t use any indexes and has to trawl through every field of every clip. It could takes minutes rather than seconds, and is a very easy “mistake” to make, so if at all possible you’re encouraged to perform a more specific search instead. Is this a big problem?
  • Justin White
    January 12, 2011 at 3:33 pm
    Not a huge problem, just kind of annoyance shared by myself and fellow co-workers/editors. Just wanted to make sure I wasn’t missing a way to avoid the message other than adding info to another field.
    Thanks for the input!
  • Kevin Duggan
    January 12, 2011 at 5:22 pm
    Hi Justin
    the very general query is a sledgehammer to crack a nut as opposed to the scalpel blade precision of an indexed query. I like to call it a query of last resort. This is why you see it is an option to display it in the Simple Query fields. It is the worst possible search in that it has to trawl the whole of the database for a match and the bigger the database the longer you have to wait. Usually you can help the speed by giving the system hints… ie what year , what series , something to get the indexed searching working . In my teaching this stuff to users you notice that we are all fundamentally lazy, so the any logging field option seems to mean that we will get what we want , so lets use that.. However we all want speed as well.So a well constructed logging schema will help your users find stuff faster. Explore so called Smart folders , they are really queries with more than one criteria , a mixture of these and teaching your users how to “GOOGLE” this stuff will make them all happy campers… There is a lot of traffic about this subject in this forum..
    Kevin Duggan
    Catdv
