Activity › Forums › Adobe Encore DVD › Very choppy file…
  • Very choppy file…
    Posted by Dale Roberts on May 15, 2013 at 1:56 am
    Hi there.
    Very new to the bluray world…
    I am doing some tests with Media Encoder as I dont have Encore or a bluray writer yet… I am looking at the files that I encode in Mpeg-2 Bluray and they look VERY choppy.. Im a little worried about it. Is this ‘normal’ for just the file? Does Encore have to do more with the actual file with more processing?
    I have also tried an dh.264 but can’t even play the file…not sure what to do about that either?
    Im flying blind I feel but no real time to get the right hardware/software with my shoot on tomorrow. Pushing it!
    Many thanks
    dale
    Dale Roberts replied 13 years, 4 months ago 3 Members · 4 Replies
  • Kris Merkel
    May 15, 2013 at 3:00 am
    Disclaimer first, I do not author BR discs
    It would help if you shared your encoding settings. I am going to just guess that you have set AME to encode at to high a Bit rate and the CPU is not able to decode tat amount of data quick enough to be real time.
    Best thing to do is start with the presets in AME and start tweaking from there. Work with a small section of your timeline so you will not have to wait for hours to see the results.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Dale Roberts
    May 15, 2013 at 9:52 am
    Hi Kris.
    Yes, i should have done that-
    Its just the MPEG 2 Bluray Preset Standard settings in 25i and 30i. I am thinking the same…
    But i just cant be sure..
    I’m on a Macbook Pro
    2.53 Ghz Intel Core i5
    4GB RAM
    NVIDIA GFORCE GT 330M Graphics card
    7200 RPM internal Drive…
  • Jeff Pulera
    May 15, 2013 at 2:15 pm
    Hi Dale,
    I concur that the laptop may not have enough juice for smooth playback. What region of the world are you in? The “25i” setting would be for PAL users only, “30i” (or 29.97) for NTSC world. Wherever you live, you would be using one or the other, but not both.
    Jeff Pulera
    Safe Harbor Computers
  • Dale Roberts
    May 16, 2013 at 8:58 am
    Thanks Jeff… yeah which is actually, probably ok for now… but yeah I am in PAL world… but I (had) thought that gopros only did 30 fps so was trying to fit that into the shoot… clearly, they do not so problem averted!
    Im shooting in 25i… really wanna try 24P but for now I am keeping it simple stoopid!
    Thanks again…
    dale
