Activity › Forums › Apple Final Cut Pro › very best way to compress for youtube
Posted by Ed Sayers on April 29, 2013 at 4:01 pmhi all
can anyone recommend the very best way to compress for youtube?
most up-to-date info only please…
this is YT latest spec guide: https://support.google.com/youtube/bin/answer.py?hl=en-GB&answer=1722171
my project is 1920×1080 (p) PAL 25fps
we’ve been using mpeg streamclip and will try compressor 4.07 next
will be using 50k bt rate (50,000)
just checking we’re not throwing away any quality we don’t need to
thanks
e.s.
Ed Sayers replied 13 years, 4 months ago 8 Members · 12 Replies -
Ed Sayers
April 29, 2013 at 4:54 pmthanks brett
just realised i posted in the FCPX forum
this project is in FCP7 and looking to compress having exported pro res
thoughts welcome…
ed
Tony Brittan
April 29, 2013 at 4:56 pmAnd if the actual sharing doesn’t work, you’ll find the converted file in the shared folder inside the project using finder. Then upload directly via a browser. Makes perfect files in my experience.
Tony Brittan
Island Shore Productions
Kill Devil Hills, NC -
Bret Williams
April 29, 2013 at 5:08 pmWhen I open up the older compressor it also has a YouTube sharing function. Not sure how up to date those settings are though.
Bill Davis
April 29, 2013 at 6:08 pmGo to the Share menu.
Select YouTube.
If you’ve set up your YouTube account ID info and password properly – you click Share and a perfectly encoded version appears in your YouTube account.
Pretty much as simple as that.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Loren Risker
April 29, 2013 at 6:14 pmYour settings look good and mpeg streamclip can get the job done.
One thing neither MPEG streamclip nor FCPX’s share to youtube doesn’t do is give you the option for fast start and compressed header. Compressor does.
Moov atom at the front of the file (Fast Start)
OutOfFocus.TV – Original series, music videos, and entertainment for your couch. -
Claude Lyneis
April 30, 2013 at 4:30 amI usually use compressor but I tried the share to Youtube approach. The video came out with these settings.
HD 720p.mov
H.264, 1,280 x 720 (1,248 x 720)
Audoe AAC, 48000 Hz, Stereo (L R
Data Rate 10.34 Mbit/s
29.97 FPSNote, the raw video was 1080i AVCHD. Of course the quicktime inspector does not show all the setting such as fast start for the internet.
Bill Davis
April 30, 2013 at 6:09 am720p scales beautifully to all sorts of modern mobile platforms. It creates lovely iPad & iPhone retina display images and great looking android and even older style cel phone deployments.
So it’s become my default. I shoot and produce in 1080 – but I typically output everything to 720p 24 frame for delivery because it both compresses and scales so well across my most important distribution platform, and that’s the internet.
FWIW.
