Activity Forums Apple Final Cut Pro Legacy very basic questions (I’m a bit counfounded)
  • very basic questions (I’m a bit counfounded)
    Posted by Rick Neely on February 5, 2011 at 6:59 pm
    Hey,
    feel a bit embarrassed to ask since this seems so basic. But here’s the thing-
    -imported some progressive AVI (DVSD codeced) footage into an FCP sequence (DV, Lower field, 29:97, 720×480). Looks great on progressive monitors. But need to output to DV tape. Previewing on an interlaced monitor, it still looks like it has interlace issues. I guess since it didn’t originate as DV Lower field, I’m not sure if I should change a setting in my record deck, a setting in the FCP sequence, or apply an interlace filter. Using the workflow I described, what would any of you FCP guys recommend?
    R
    Zane Barker replied 15 years, 7 months ago 3 Members · 2 Replies
  • Alan Thorburn
    February 6, 2011 at 12:17 am
    Try reversing the fields of the troublesome shots by applying the Shift Fields filter found in the Video folder in Effects.
    Alan
  • Zane Barker
    February 6, 2011 at 1:19 am
    FCP is QuickTime based and avi files are NOT QuickTime based.
    You need to convert the files to a proper FCP editing codec before bringing them into FCP.
    **Hindsight is always 1080p**
