Activity › Forums › Apple Final Cut Pro Legacy › Very annoying capture problems
Posted by Josh Evans on May 15, 2008 at 2:59 amI am capturing footage in SD, every single time i try and capture, it stops after 8 minutes or so and says “Clip Error” and i have to try again with no luck.
Has anyone ever had this problem:?
[EDIT] I should add that the other half of the time it just stops capturing and says something about dropped frames. I never had this problem before…. HELP!
Josh Evans replied 18 years, 4 months ago 7 Members · 10 Replies -
Aaron Neitz
May 15, 2008 at 3:13 amMas specifics for favor:
What’s your system setup? In/out hardware?
What’s your source? DV tape? Digibeta?
What kind of drive are you digitizing to?
Versions of everything: OSX, FCP, QT, etc… -
Steve Eisen
May 15, 2008 at 3:44 amMake sure your hard drive is formated as HFS+
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Josh Evans
May 15, 2008 at 3:50 amI am importing on DV on my SONY HRV-V1E
my FCP and OSX are both latest versions, as well as my QT.
I am using a Lacie 1TB professional 2 disc RAID.
Alan Okey
May 15, 2008 at 7:10 amIs your LaCie RAID connected via Firewire? Capturing DV to FIrewire drives can be problematic because all Firewire devices share the same bus and the bus speed defaults to the slowest device. Try capturing to a different (internal) drive and see if that solves the problem.
It’s a better idea to use internal or eSATA drives (but not the system drive) for higher performance.
Thoren Lowe
May 15, 2008 at 10:35 amGo to disk utility, there you will see a list of drives, click on the top level of your lacie and see what it says on the right. If it is an NTFS formatted drive it will not take files larger than 2GB. which is why it would stop at 8mins every time.
You can also format your drive from here (choose Mac OSX extended (journaled)) but note that it will wipe everything that is on the drive.
Hope that helps!
Thoren
Walter Biscardi
May 15, 2008 at 11:40 amIs your Drive formatted MAC Os Extended?
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Katie Van
May 16, 2008 at 12:16 amYou’ve probably already tried this, but did you check your capture settings?
Uncheck “Abort Capture on dropped frames” in the General tab of User Preferences.
And if it was the drive thing that the other person suggested, could you post a response about the solution? Just for my own curiosity.
Good luck
Josh Evans
May 16, 2008 at 7:48 amI cant see anything on the right about the drive, but it does say that its format is mac osx extended (journaled)
I remember someone telling me not to have it journaled. Does this slow it down somehow?
