Activity Forums Adobe After Effects Vertically centring paragraph text
  • Vertically centring paragraph text
    Posted by John Mcpherson on July 24, 2015 at 11:25 am
    I am using a template composition to substitute various lengths of text in a number of instances of a custom graphic in Premiere Pro CC2015. The custom graphic contains a circle shape with the template text set up as paragraph text with its bounding box centred above the circle. Although I can centre justify the text horizontally within the bounding box, I cannot find a way of centring the text vertically within the bounding box. The solution I am looking for must work automatically with the various length text strings used for the different instances throughout the Premiere sequence.
    John Mcpherson replied 10 years, 9 months ago 1 Member · 1 Reply
  • John Mcpherson
    July 24, 2015 at 10:56 pm
    Thanks for your response Dave. I had just about come to that conclusion myself after a lot of on line searching but wanted expert confirmation from an industry expert such as yourself. I did find a Mamoworld script advertised that does something similar but it lacks the precision I was after. I would be interested to know how many other users have hit the brick wall on this one. If a lot, perhaps this should be a new feature request to Adobe.
