Activity Forums DaVinci Resolve Vertical Wipe transition for DaVinci Resolve 12.5
  • Vertical Wipe transition for DaVinci Resolve 12.5
    Posted by Allen Zagel on June 25, 2017 at 12:10 am
    Where can I find a Vertical Wipe transition for DaVinci Resolve 12.5. I need it for an easy way to animate a map showing a route. The wipe in Resolve is horizontal. I don’t see how can change that one.
    Allen
    Marc Wielage replied 9 years, 2 months ago 3 Members · 2 Replies
  • Glenn Sakatch
    June 25, 2017 at 4:29 pm
    you could put the clean map on V1, the map with the line on V2, add an alpha output on V2, and animate a power window to expose the line on V2. This would allow a much more dynamic line to be drawn.
    Glenn
  • Marc Wielage
    June 26, 2017 at 1:53 am
    It’s not real intuitive, but the EDGE WIPE transition is rotatable so you can do either a horizontal wipe or a vertical wipe or any Angle degree shift you want. 90° or -90° should give you what you want.
