Activity › Forums › Apple Final Cut Pro Legacy › Vertical video lines visible in FCP viewer? Normal?
Posted by Khashyar Darvich on May 31, 2006 at 7:33 pmHi Everyone,
Are visible vertical lines in DV video in the FCP viewer window normal?
I can’t see the verticle lines from the same footage in my Sony PVM-14L5 monitor that I have connected through an AJA LHe card.
My monitor is an Apple 30″ cinema display.
I have read that NTSc video is interlaced video, and that compuer monitors are Progressive, and that NTSC video will not appear properly on a computer monitor.
Are the visible vertical lines in video on the computer monitor a result of a progressive scan of the video frames as opposed to the interlaced scanning of the video?
I am planning on blowing up my current documentary either to 35mm film or for digital projection, and I want to minimize any visible lines (vertical or horizontal).
Thanks for calrifying the vertical lines issue,
Khashyar
Khashyar Darvich replied 20 years, 4 months ago 3 Members · 10 Replies -
Khashyar Darvich
May 31, 2006 at 10:42 pmHello,
Has anyone experienced the same visible verticle lines issue on a computer monitor? Is this normal because of the interlaced nature of NTSC, and the noninterlaced nature of a computer monitor?
Khashyar
Andy Mees
June 1, 2006 at 3:28 am[Khashyar Darvich] “Are visible vertical lines in DV video in the FCP viewer window normal?”
no, this doesn’t sound normal
[Khashyar Darvich] “I can’t see the verticle lines from the same footage in my Sony PVM-14L5 monitor that I have connected through an AJA LHe card.”
then its ok… what you are monitoring on the PVM through the AJA card is the ‘true’ image … the one on the computer display is only a ‘preview’
[Khashyar Darvich] “Are the visible vertical lines in video on the computer monitor a result of a progressive scan of the video frames as opposed to the interlaced scanning of the video?”
interlacing artefacts tend to show up more as horizontal lines, not vertical … can you post a screen shot so we could see the specific problem
Khashyar Darvich
June 1, 2006 at 5:52 amThanks for offering your feedback, Andy.
Would I need to post a link to the screenshot after posting it on my website?
Khashyar
Andy Mees
June 1, 2006 at 7:16 amsure, that would give everyone a chance to look and see if its an identifiable problem
Khashyar Darvich
June 1, 2006 at 7:33 amAs Andy recommended, here are screen shots to the vertical lines that I am noticing:
Clip #1 (Full size)> https://www.wakan.com/images/fcp/example_1_wide.jpg
Clip #1 (Closeup)> https://www.wakan.com/images/fcp/example_1_cu.jpg
Clip #2 (Full size)> https://www.wakan.com/images/fcp/example_2_wide.jpg
Clip #2 (CU)> https://www.wakan.com/images/fcp/example_2_cu.jpg
Clip #3 (Full size)> https://www.wakan.com/images/fcp/example_3_wide.jpg
Clip #3 (CU)> https://www.wakan.com/images/fcp/example_3_cu.jpg
Thanks for any feedback,
Khashyar
Andy Mees
June 1, 2006 at 8:34 amunfortunately, I think you’ll find those images are only showing typical DV chroma compression artefacts … not something you can easily avoid when working with DV! You can see too much detail on the fancy 30″ monitor of yours …
you will find a wealth of technical info on all things DV at Adam Wilt’s website:
https://www.adamwilt.com/DV.htmlalso highly recommended is Graeme Nattress’ Chroma Sampling article at the LAFCPUG website:
https://www.lafcpug.org/Tutorials/basic_chroma_sample.html -
Jim Martin
June 1, 2006 at 3:42 pmall of those screen shots you posted are over 100%, and the CU’s are 400%
You can’t blow up DV without seeing compression garbageJim
Khashyar Darvich
June 1, 2006 at 4:10 pmThank you both for your feedback. I feel better, especially since I cannot see the vertical pixel lines in the NTSC monitor.
I bought the 30″ cinema monitor a month ago, and I suppose that I was not used to the improved image from my last CRT monitor.
I have a question, though. How are films, that have been shot in DV, able to be blown up to 35mm film without showing the pixelation? I know that video-to-film houses use special software as part of the conversion process (which “softens” pixelation, I believe).
Thanks again for your thoughts and feedback.
Khashyar
Khashyar Darvich
June 1, 2006 at 4:15 pmI want to also mention that when I play a DVD of a documentary film in full screen view on the 30″ monitor, I don’t see any pixelation at all. Is this because the movie has a different (MPEG4) compression?
I believe that the film (“The Ballad of Bering Strait”) was also shot in DV, but it was later transferred to film for theatrical release.
Why does a DVD not show the pixelation when viewed in full screen mode on the monitor?
Khashyar
Khashyar Darvich
June 1, 2006 at 6:17 pmHello,
Andy and Jim mentioned that the vertical pixelation was a normal artifact of the compressed DV format.
I wonder if you show an uncompressed BetaSP clip at the same viewer window size, if you can also see vetical pixelation? I wonder this because I was reading that while computer monitors employ square pixels, NTSC video monitors use retangular pixels. Could this cause a distorted look when looking at DV video in a computer monitor?
Khashyar
