Activity Forums Adobe Premiere Pro Vertical Video Format
  • Vertical Video Format
    Posted by Jonathan Swihart on September 15, 2010 at 1:39 pm
    I’ve been asked to create a vertical video for a trade-show. Their monitor will vertically be 1080X1920 standing up. So I’ll be taking their horizontal photos and moving them across this tall layout. How do I set-up my Adobe premiere to make this happen? If you can get me started with SET-UP on this approach, I should be fine.
    Jonathan Swihart replied 15 years, 3 months ago 3 Members · 4 Replies
  • Ann Bens
    September 15, 2010 at 6:28 pm
    You can set your vertikal sequence up via Desktop.
  • Kitt Phi
    June 5, 2011 at 11:36 pm
    Hi Jonathan, I was wondering if you got this to work. I’ve been trying to do the same thing. Can’t figure it out. Thanks,
    Kitt
  • Kitt Phi
    June 5, 2011 at 11:38 pm
    Hi Ann, I didn’t see an option in Sequence to change it to vertical. I am running CS4. Is is also possible to export it so that it will play vertically, or do i just do all the work side ways and then turn the LCD?
  • Jonathan Swihart
    June 6, 2011 at 12:34 am
    Naturally your setup is set for LANDSCAPE view, so all you need to do is spin each image that goes into the project so that the top is actually on the right. It’ll make you sick to tilt your head while editing a long project, so I would use an extra monitor that you can tilt during this edit process. My project was a simple slideshow, so all I had to do was pan my images left to right (or in the tilted case TOP TO BOTTOM).
