Activity Forums Apple Motion Vertical Text Alignment
  • Vertical Text Alignment
    Posted by Stephen Botting on February 11, 2013 at 3:59 am
    Hi All,
    I’m creating a text field that will be edited in FCP, but the length of text in this field will change. Is there a way to make it when a new line is added to the text, all the lines moves up to make room for the new one, thus the bottom line of text is always the same vertical position.
    Stephen
    Mark Spencer replied 13 years, 7 months ago 2 Members · 3 Replies
  • Mark Spencer
    February 11, 2013 at 4:02 am
    Set the Layout Method (Text > Layout) to paragraph and set the Vertical Alignment (Text > Format) to bottom.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Stephen Botting
    February 11, 2013 at 8:24 pm
    Thanks for the reply.
    I cannot find the Vertical Alignment option in Format. I’m only using Motion 4, this isn’t a new feature of Motion 5 is it.
    Stephen
    https://www.43south.co.nz
  • Mark Spencer
    February 11, 2013 at 9:37 pm
    Could be. I’m on 5 now.
    Mark Spencer
