Activity › Forums › Web Design (WordPress, Joomla, etc.) › Vertical Spry Menu Bar items are on top of each other
  • Fernando Mol
    July 2, 2010 at 4:35 pm
    Your site runs fine on IE, Firefox an Safari on Windows 7
    *Always share a link to your site and rate the posts. This is a free service for you and for us.
  • David Shipp
    July 3, 2010 at 4:36 am
    It is not working in Firefox or Chrome under Windows XP for me. See the screenshot attached – it shows Firefox and IE side by side. This is using Firefox 3.6.6 – just downloaded it. Same happens on Safari, both in Mac and Windows XP.
  • David Shipp
    July 3, 2010 at 3:25 pm
    Apparently the screenshot did not attach to my post. Here is a link to it:
    https://dl.dropbox.com/u/8217775/Firefox%20menu.jpg
  • Fernando Mol
    July 4, 2010 at 1:25 am
    Oh, I see, I was checking your horizontal spry menu.
    If you are going to place more than a spry menu you should change the default spry folder in the preferences for each instance.
  • David Shipp
    July 4, 2010 at 3:54 am
    So, are you saying this could be fixed by simply copying the SpryAssets folder, duplicating it as Spry AssetsVertical and then deleting the parts out that apply to the other menu?
    Thanks for taking the time to look at this.
  • Fernando Mol
    July 4, 2010 at 1:39 pm
    What I’m saying is that having multiple instances of the same spry asset using the same spry folder can cause you troubles. You should backup and test.
